What to do when heating season is over?
ImYoungxD
in Oil Heating
I'm a new home owner and not sure what to do after we no longer use the oil burner for months.
I currently have 1/4 oil left in the tank.
Should it remain low or should I fill it up around June/July when oil prices are lowest?
What do I do with the water in the tank?
What else should I be doing?
Thanks
Thanks
First there is no rhyme or reason to oil prices, so waiting for them to drop may not be a good economical decision.
Are you getting heating oil or a bioheat?
I'd do one of 2 things. I'd wait until fall, and have the oil company put in an additive, and fill the tank. A few days or more after that, I would have the boiler/furnace cleaned, full tune up, and have the tech drain a little oil off the bottom of the tank to check/remove any water that may have accumulated in the tank.
Conventional thought is to fill the tank in the spring so no condensation can form in the tank.There was an error rendering this rich post.
It seems like you have a cold start aquastat, meaning the burner will only fire with a heat call. Either that or you want to shut it down for the warm months, which is not a great idea.
What provides the domestic hot water?
First time dealing with oil heating?
Post some pics of the boiler and water heater with surounding piping.0 -
I have heating oil which is only used for steam heating. Gas for everything else. As for the water in the tank what I really meant was the water in the boiler. Do I leave it alone?
I have hot water heating for the basement (have aquastat) and steam for 1st and 2nd floor.
The basement calls for heat to the aquastat. I don't need heat in the basement so it's always at 50F0 -
If your not familiar with steam boilers you either have to read up on them extensively to learn how to take care of it or have a steam qualified plumber take care of it for you every year and hope whoever installed the steam boiler did the installation correctly.
Weep.New England SteamWorks
newenglandsteamworks.com1 -
But once having dried your eyes, -you should keep your oil tank full. Have them top it off when heating season ends. Otherwise, in your warm, humid, & summer basement condensate will form in the tank, and water in the tank is never your friend.
Next you should also call your favorite steam professional and have him go through your boiler and system for annual maintenance, making sure you're ready for next winter.
Then, and only then, may you turn your sights to mowing the lawn.New England SteamWorks
newenglandsteamworks.com0 -
Rejoice, my LP bill goes awayNew England SteamWorks said:What to do when heating season is over?
Weep.
I have to continue hauling anthracite rice coal for the 2018-19 heating season stockpile and then continue hauling coal every month when the heating season starts.
I have no oil bill(my tank is empty) My old oil dealer made the mistake of letting my oil tank run out four times and I barely use any propane during the heating season.0 -
Happy 100 years agoleonz said:I have to continue hauling anthracite rice coal for the 2018-19 heating season stockpile and then continue hauling coal every month when the heating season starts.
I have no oil bill(my tank is empty) My old oil dealer made the mistake of letting my oil tank run out four times and I barely use any propane during the heating season.There was an error rendering this rich post.
2
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
