Hot Water Heating System Sealant...
Andy_d
Member Posts: 10
Is there a Hydronic system sealant for pex pipe. I know there is for boilers, but i have a customer asking me if there is. We have a digester that is wrapped in pex and pinholes have developed. Without going into more detail, all i need to know is if anyone has heard of such a product. I haven't seen anything in my 30 years of plumbing wholesale, but maybe I've missed something.
Hmmmm , neither did I...
I've used the Fernox brand sealers in rubber tube in slab that had small leaks, pin holes I assume. Sometimes it works sometimes not, really depends on the size, number of, holes and I suspect expansion and contraction causing the hole size to change.
The stuff i used is a milky white product, almost looks like diluted Elmers glue
I suspect some insect was boring it to the tube for a source of water or warmth, as it was in a greenhouse application.
When we finally chopped open the slab, in the case where the sealer did not work the tube looked like it has bore or chew marks.Bob "hot rod" Rohr
Living the hydronic dream0
- 52 Job Opportunities
