Hot Water Heating System Sealant...
Andy_d
Andy_d Member Posts: 10
Is there a Hydronic system sealant for pex pipe. I know there is for boilers, but i have a customer asking me if there is. We have a digester that is wrapped in pex and pinholes have developed. Without going into more detail, all i need to know is if anyone has heard of such a product. I haven't seen anything in my 30 years of plumbing wholesale, but maybe I've missed something.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,550
    Hmmmm , neither did I...
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,159
    Hello, Might it be time to go into more detail? I'm curious to know what's causing pin-holing in PEX. Perhaps we can try to address the root cause. ;)
    Yours, Larry
    delta T
    hot_rod Member Posts: 27,829
    I've used the Fernox brand sealers in rubber tube in slab that had small leaks, pin holes I assume. Sometimes it works sometimes not, really depends on the size, number of, holes and I suspect expansion and contraction causing the hole size to change.
    The stuff i used is a milky white product, almost looks like diluted Elmers glue :)
    I suspect some insect was boring it to the tube for a source of water or warmth, as it was in a greenhouse application.
    When we finally chopped open the slab, in the case where the sealer did not work the tube looked like it has bore or chew marks.
