Prehistoric Monitor Top?
nicholas bonham-carter
Member Posts: 8,578
Even older than Chrisj’s-they just don’t build things to last like this now!—NBC
http://www.dailymail.co.uk/sciencetech/article-5371479/An-Iron-Age-FRIDGE-discovered-Isle-Lewis.html
1
@nicholas bonham-carter , Did you intend to include a picture?0
Sometimes cut and paste turns into just cut!—NBC
http://www.dailymail.co.uk/sciencetech/article-5371479/An-Iron-Age-FRIDGE-discovered-Isle-Lewis.html0 -
> @Mike Cascio said:
> Can kill the Monitor top. Mine is still going strong after 83years.
That looks like a 1936 model.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Our 1950’s Norge stove-still going strong, except for the temperature marks on the oven dial, which are worn off.
The stainless steel top matches the 1920 stainless steel counter tops perfectly.—NBC0 -
Nice Stove!
Chris, do you know what year the clock is from. I was thinking somewhere close to 1930 but am not sure. I bought the monitor top off the granddaughter of the original owner. She kept her grandmothers house which was built in 1929 with all of its contents.0 -
I can try to find out.Mike Cascio said:Nice Stove!
I want to say they were given away as advertising during the early years, 1927-28ish? But I'm not an expert on the clocks. Does it still run? The clock I mean........... The CK machine you have from 1936 it's almost a given that it runs.
I have a restored 1933 in my kitchen.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The clock and the ck work perfect. Even the defrost function works.0
- 167 Indoor-Air Quality
