Tigerloop and filter change
ERF
Member Posts: 51
in Oil Heating
Vacuum gauge on tigerloop was creeping up too 7 inches of Hg.
Water separator filter installed Sept 2017, changed today Feb 14 2018. When boiler fired up vacuum reading is 0 inches through out the burn cycle. The 2 following 10 micron filters were installed in 2016 and still have not been changed.
those gauges go bad all the time"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
There seem to be three of the same filters in series .. Yes only the first one would get dirty , The last two will do nothing... In parriell would make an bigger filter . Finer filters down stream .. Best off moving one by the tank to cover the oil line ... The fire-o-matic safety valve should be before any rubber gasket not after.. ,
@newagedawn have another new gauge, will change out and see if there is a difference.0
