Looking for Flame Rod lead wire.
Dave338
Dave338 Member Posts: 6
I need to find a source for the wire for flame rods. Anybody know where to buy it. Honeywell can't get it right now.
Thanks in advance
  • JUGHNE
    JUGHNE Member Posts: 11,513
    Some power burners I see the same type cable for ignition and flame sensing. Well insulated and temp rated but can be bulky for some installs.
    Dave338
    EBEBRATT-Ed Member Posts: 19,602
    A burner supply house should have it. If not goggle "WESTWOOD PRODUCTS" & you could call them and see who you can buy from in your area
    Dave338
  • BobC
    BobC Member Posts: 5,539
    Asbestos wire was used in the past but it's pretty much gone the way of the dodo. Silicone rubber insulated wire should do well in that application.
    Bob
    3PSI gauge
    Dave338
