Leaking Burnham V75 section
razzor
Member Posts: 20
I have a 20 year old Burnham V75 hot water boiler that has sprung a 2” horizontal crack in one section and leaks when furnace is running. I have a plastic storage container under it and it leaks about a 1/2 “ of water a day. it seems to be running ok. Have LWC and auto fill. I live in Maine so can I make it through the winter until I have enough money to get a new boiler in the spring?
It depends on how you define "make it through". At the very least the problem will stay the same and just be a pain in the ****.
There's a possibility that it could become much worse without any warning.
Those boilers are known leakers, I've seen a bunch fail while still under warranty.
If you have the means to do so, I recommend replacing it as soon as possible and consider yourself lucky that it didn't flood your house0 -
Thanks Supertech. I mean make it until mid April. It is basically weeping just in that one section out of 5 sections. I have let it go for 6 days and had about 5 “ of water in a 16x25x13 storage container. I have fixed it so it doesn’t leak on the floor. I just don’t have the funds to replace right now.0
@razzor , chances are it will stay the same you only have two months to go.
Start doing your homework by selecting the new boiler , check to make sure it's the correct size by doing or having someone do a heat loss.0 -
This is the section that is leaking.
> @EBEBRATT-Ed said:
> Too bad. I am old school and still think a cast iron boiler, (especially a water boiler) should last more than 20 years
Agree. But I don't think the Burnham V7,V8 went to school.1 -
It's too bad about Burnham. Because of those typical failures that I still doubt the quality of the product they produce. It seems like newer ones are nicer but I won't be fooled again.0
Takes years for the trade to forget .
