Big mouth dumping water
I visited a job site with a customer. They installed a Mega Steam boiler about a year ago. During a service call in December the tech noticed an air vent spewing water . It is located on the dry return just above the boiler and two other returns tie in just below the vent. They replaced the vent with a big mouth vent and it continues to spew water . Since December the feeder has registered 133 gallons of new water . The steam pressure is at 1.5 psi with a 1 psi differential . The dimension A is good. Over 32 inches . The boiler is piped perfectly but it appears to be surging a bit .
Could a dirty boiler cause this.
  • BobC
    BobC Member Posts: 5,566
    Big Mouths have no float so they can't stop water. I think a good long skim session is in order, it may take more than one to get that water clean but the first skim will quiet the surging initially.
    Bob
    3PSI gauge
    Mark N
