Riello boilers!
hot_rod
Member Posts: 25,384
Can an oil fired be in the works?
7:1 turndown with 19.6K minimum output....
Wonder why we haven't seen any 10:1 turndown 50-60K BTU boilers yet? 5k BTU output would be great for smaller energy efficient homes with zoning.0 -
The combustion becomes unstable when you increase the turndown ratio. I also believe that the ratio or percentage of excess air you require for combustion goes up with the turndown ratio. This will reduce your efficiency negating the gains you get for installing a modcon.0
How are their oil burner OEM customers going to feel about it?To learn more about this professional, click here to visit their ad in Find A Contractor.1
There is no theoretical reason why an oil burner can't be made to operate with a wide turndown ratio with excellent efficiency across the range. Gas turbines do it routinely. So do power generation boilers. The latter do it mostly by turning various burners or combinations of burners on or off as the load varies -- the average home oil burner has just one, so that's not an option (well... it is, and I've discussed it elsewhere, but for the moment let it go). Gas turbines do it by varying fuel and air flow to the combustion chamber -- but have you ever looked closely at how a gas turbine does that? The controls and sensors alone -- even for a 200 shaft horsepower turbine -- run well into six figures, never mind the nozzles...
So the question really is, yes it can be done, but can it be done at a price point which makes sense? Be interesting to watch.Br. Jamie, osb
I've always wanted to try one of these small diesel hydronic heater on a hydronic system. I know a few other motor home builders that use them for hydronic heating.
I'm building a 10' slide in camper for my truck, if I can find a deal on one I may try some radiant and panel rads. 7- 17,000 BTU/hr.Bob "hot rod" Rohr
I don't know much about them, but would an electronically controlled oil pot burner work in a small condensing boiler application? Those Toyotomi Laser heaters seem to use them and burn cleanly on very small outputs. It's been my understanding that the vapor pressure nozzle has been the hold back to small output oil equipment.
Someone correct me if I'm wrong!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
