How water hammer can damage a steam-to-water heat exchanger
HeatingHelp
Administrator Posts: 721
This reminds me of an apprentice I sent to install a vacumn breaker on a 100 percent outside .air coil installation. I recieved a call that to this day makes me get a headache. That thing your guy put on is melting! What!!!! I go out to the site and the thing was in fact melting. The guy who knew everything had installed a vacumn breaker for potable water on the steam system. He would tell anyone who would listen he was God himself to the trade. Problemn was he was a backstabbing knuckle head I have never enjoyed firing anyone ,but I made an exception for him, ahole.
All the best Jack0 -
Having recalled reading this story some years ago in a magazine column. I installed new condensing water heaters in a hospital that had a boiler up on steam 24/7/365 for nearly 40 years.
They have a good sized steam shell to water tube bundle for building heating. I removed a steam tube bundle from the old tank. So the boilers would be down most of the summer.
I printed the article out to convince the maint man that he need a vac breaker and also an air vent. They are now installed on the HXC. Had the hammer damage happened I would have been somewhat at fault for shutting down the steam.
If no problem then he may wonder way did I sell those items?
One just has to sound convincing and it helps to have an article written by an authority who is at least 100 miles away.
BTW Dan, Thanks for it and others!0
