Humidity and Steam Heat
Major7
Member Posts: 44
I live in a neighborhood where lots of homes still have steam heat. One neighbor suggested that the heating system can humidify the house by venting steam into the room. I have never heard of this before. Is this really a thing that can be done?
My home has been in the low teens humidity wise with this recent cold snap. I'd appreciate all your opinions on the matter.
If you're using steam from your heating system to bring up the humidity levels, your boiler is going to die a quick death from all the fresh water that will have to be replaced.
The low humidity is from air leaking into your home from outside. Seal the leaks and save some money on your heating billYou can have it good, fast or cheap. Pick two2 -
My Aprilair Steam humidifier boiler can boiler 20 gallons per day to keep it just 20-25%rh on the coldest days. You should see the pile of minerals in the bottom of the plastic tank it has. It blows down about once every hour or so of run time. So water use is another 8-10 gallons or so I’d guess.
At minimum you’d need a deaeration tank. Even then expect short boiler life.
The tiny amount of damp air the vents purge is negligible. Maybe a cup a week.0 -
Thanks for the feedback everyone!0
https://www.overstock.com/Home-Garden/Snow-Joe-Old-Fashioned-Radiator-Humidifier-for-Steam-Heat-Units/16741324/product.html?refccid=U4EQPLE3VADYFKKOGPBGLSEADU&searchidx=38&keywords=&refinement=
One house I went in had similar devices As the one in the link on their radiators. The homeowner told me they made an improvement
Google radiator humidifiers0 -
Seeing as how my steam humidifier probably puts out over 10 gallon a day to keep up, this would help, but ultimately a drop in the bucket, at least in my house. I'd need one of these in every room and refill them daily...all 15 of them.
There are steam humidifier with fan powered kits.
- 120 Geothermal
