Crud on the sight glass
Garsha
Member Posts: 18
in Oil Heating
Along with other issues I've been having, the sight glass on the boiler is damp on the base with what smells like oil. I don't know what could cause this...
The boiler is on it's second heating season. Is there any reason it would screw up so quickly?0
Thank you. Can you share with me how the condition of the water is a sign of steam leaks somewhere in the system (kitchen), also if and how that can cause the guage to go bad? I would really appreciate the lesson. I had no idea.0
No the glass gauge went bad from leaking . The leaking energy thins out the glass...
When water boils into an vapor it leaves behind minerals that was once diluted in soultion ... We call the minerals solids ...
Steam heat is an closed system , The vents act quickly and shut off once the steam enters its chamber.. The steam condenses when it gives off. its laiden heat .. The condensate returns back to boiler . There should be no water loss , only by the service flushing ... The mud is telling me your adding lots of water and steam is escaping ..Which is solids left behind ..
Set the thermostat to 80*and let it run up to steam pressure .. Walk around the house and basement and listen for the big leaks .. The small leaks check the radiator valve stem packing and loose radiator unions .. It will fog an mirror if your not sure ...
Incredibly insightful! Thank you.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
