Water hammer in return line from Baseboard heating attached to steam boiler
Thats why I had to drain the water. Today I took off the coupling and soldered a pipe in place0
Here are the pictures of the new pipe soldered in and the new 3/4 ball check valve.
I also discovered that if you open the water to fill the boiler it will flush the boiler thru the valve I put on the bottom of the baseboard return.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
