Injection Mixing Controller for Modulating Valves
Bergie
Member Posts: 2
So I've looked through past posts on injection mixing, and mostly what I see are applications using an injection pump. Pretty much all that I can find on manufacturers websites are controls for injection pumps as well. I am trying to fix an existing system that uses valves for the injection control. I am looking for a controller that will modulate the valves based on zone loop temp, but have boiler protection as well. ODR would be a bonus. The Tekmar 360 is as close as I can find, which would work, but I have two zones I want to control with the same unit. If anybody has any recommendations or suggestions, I would love to hear them!
Sort through these . Probably find what you need .
http://www.taco-hvac.com/uploads/FileLibrary/100-19.pdf
http://www.taco-hvac.com/uploads/FileLibrary/102-145.pdfYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Yeah, that'll do. I appreciate the lead!0
