Will the big mouth fit? Images attached
ImYoungxD
ImYoungxD Member Posts: 130
Current vent is Gorton #1 and I would like to upgrade. The vent is a bit tilted. Not sure if it affects the venting but I have no issues.
See images
TIA
Gsmith
  • Fred
    Fred Member Posts: 8,542
    Big Mouth should fit. It is a 2 part unit. You screw the bottom half of the union into the pipe opening and then you can hold the top part (the actual venting portion) in place and tighten the union onto the part that you screwed into the pipe. The entire unit does not need to turn. Flat side towards the joist and venting side out.
  • ImYoungxD
    @Fred that's great to hear. Thank you for the fast response.
  • gerry gill
    gerry gill Member Posts: 3,083
    why not use a Barnes and Jones vari vent? I use them and love them.
    gwgillplumbingandheating.com
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    For more head room replace the nipple and elbow with a street 90?—NBC
    New England SteamWorks
  • JUGHNE
    JUGHNE Member Posts: 11,513
    If the nipple would come or not, I would add a 90 with a long nipple and an another 90 with vertical riser if possible.
    IMO the more length and 90's you have the less chance of water hammer, debris and actual water hitting your new vent. You want the horizontal nipple sloped to drain back into the main pipe.
