Will the big mouth fit? Images attached
ImYoungxD
Member Posts: 130
Big Mouth should fit. It is a 2 part unit. You screw the bottom half of the union into the pipe opening and then you can hold the top part (the actual venting portion) in place and tighten the union onto the part that you screwed into the pipe. The entire unit does not need to turn. Flat side towards the joist and venting side out.0
why not use a Barnes and Jones vari vent? I use them and love them.gwgillplumbingandheating.com
If the nipple would come or not, I would add a 90 with a long nipple and an another 90 with vertical riser if possible.
IMO the more length and 90's you have the less chance of water hammer, debris and actual water hitting your new vent. You want the horizontal nipple sloped to drain back into the main pipe.1
- 84.4K THE MAIN WALL
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3.1K Oil Heating
- 57 Pipe Deterioration
- 801 Plumbing
- 5.5K Radiant Heating
- 372 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 39 Industry Classes
- 81 Job Opportunities
- 22 Recall Announcements
