Webster Vent Trap No. 23 and Webster Boiler Return Trap No. 0
gchalfant
Member Posts: 5
Before I open them up are there any rebuild kits available or just clean existing parts
Send an email to either Barnes and Jones or Tunstal, and you may get a quicker response.
Are they not working?
Sailah from Barnes and Jones is a regular contributor here:
https://forum.heatinghelp.com/profile/Sailah
—NBC0 -
Each Trap has 1/2" plug which i have taken out to look inside best i can, during operation of boiler nothing changes if plugs are out or in. during start up I can some times hear and feel cold air venting out the vent trap but no sounds or anything from the BRT. I suspect both have mud in bottom. Thinking about just sticking hose in plug hole to try and clean out? Don't want to take off cover plates unless rebuild parts are available0
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
