Vent to the outside
CraigMI
Member Posts: 2
Hello.
I recently bought a house with steam heat. The boiler is in the basement. In the attached picture, you can see an insulated duct. At the top it is connected to a vent to the outside and it is open at the bottom. It's about 10 degrees here in Michigan, so cold air is pouring into my basement.
My question is, what is the purpose of this and can i cover it?
Thanks in advance.
It's probably there to bring combustion air into the boiler room. How bit is the boiler? How big is the space the boiler is in? And can the boiler draw combustion air from anywhere else in the house easily?Br. Jamie, osb
The purpose of it is likely to bring combustion air to the boiler. Apparently your boiler room is too small and or too tight.
Now the bad news is, it's hard to tell with the insulation in the way but that boiler looks like it may be piped poorly....Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
-1 -
It should be possible to put an automatic damper in that duct, with an interlock that won't let the burner start unless the damper is open. Kind of like a stack damper on an atmospheric gas boiler.
That gives me an idea- wire up a standard stack damper to a fan center relay?All Steamed Up, Inc.
Consulting-1 -
I did that.
The damper motor has an end switch that completes the call for heat aftet damper opens.
Just wanted to show @CraigMI an example0 -
Thanks everyone for your feedback. The room is very small, so I'm sure you all are right.
A couple questions:
1. Is it ok to insulate the room to prevent the cold air from cooling the basement?
2. Could I temporary block the vent and leave the door open to the room?
1. YesCraigMI said:Thanks everyone for your feedback. The room is very small, so I'm sure you all are right.
A couple questions:
2. Probably not a really good idea...Br. Jamie, osb
