Vent to the outside
Hello.
I recently bought a house with steam heat. The boiler is in the basement. In the attached picture, you can see an insulated duct. At the top it is connected to a vent to the outside and it is open at the bottom. It's about 10 degrees here in Michigan, so cold air is pouring into my basement.
My question is, what is the purpose of this and can i cover it?
Thanks in advance.
    Jamie Hall Member Posts: 26,266
    It's probably there to bring combustion air into the boiler room. How bit is the boiler? How big is the space the boiler is in? And can the boiler draw combustion air from anywhere else in the house easily?
    Canucker
  • ChrisJ
    ChrisJ Member Posts: 16,893
    edited December 2017
    The purpose of it is likely to bring combustion air to the boiler. Apparently your boiler room is too small and or too tight.
    Now the bad news is, it's hard to tell with the insulation in the way but that boiler looks like it may be piped poorly....
    CraigMI
    Steamhead Member Posts: 17,936
    It should be possible to put an automatic damper in that duct, with an interlock that won't let the burner start unless the damper is open. Kind of like a stack damper on an atmospheric gas boiler.
    That gives me an idea- wire up a standard stack damper to a fan center relay?
    Consulting
    CraigMI
  • AMservices
    AMservices Member Posts: 611
    I did that.
    The damper motor has an end switch that completes the call for heat aftet damper opens.
    Just wanted to show @CraigMI an example
    CanuckerCraigMI
  • CraigMI
    CraigMI Member Posts: 2
    Thanks everyone for your feedback. The room is very small, so I'm sure you all are right.
    A couple questions:
    1. Is it ok to insulate the room to prevent the cold air from cooling the basement?
    2. Could I temporary block the vent and leave the door open to the room?
    A couple questions:
    1. Yes
    2. Probably not a really good idea...
