Chimney liner needed in New Jersey for oil burner replacement?
mushrat
Member Posts: 5
in Oil Heating
Hello, I have a a 16" square concrete chimney with an 8" round center built in 1950 with no terra cotta liner running up through the center of a 2 story cape. Does anyone know if I will be required to install a stainless liner for my new boiler installation to pass inspection in New Jersey if I am staying with oil? Thanks and please forgive me if this topic has been covered before as I am a new member
Can't say for New Jersey but in Omaha Yes. Even if there was a liner may still need new liner depends on size of liner, if that's not confusing.0
To answer your question a new stainless steel liner is required by code even if your staying with oil.0
Thank you both for your input, this installation price is quickly rising Yikes!0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
