How to clean this heater.
Hilly
Member Posts: 429
Naturally I am away for the holidays and don't fly back just yet. My buddy has no heat from this heater. He said it's always worked great. If I recall it's massively oversized for the room. Then I remembered he got a dog a couple of years ago. So I said try cleaning the fins. How does this style unit open. It's obvious the fins need some cleaning. I'm hoping that's the only issue.
So the Q's are, what brand is this and how does it open.
A little hard to answer any of the questions... without at least one picture...Br. Jamie, osb
That's just a plain old convector. Probably 4 screws in the front cover and pull the big front cover off starting at the bottom and vacuum it out.0
I said pull the front.... I figure it was either hinged or friction fit.0
Attach your shop vac hose to the outlet and blow the dust out.All Steamed Up, Inc.
Consulting0 -
That's what I told him to try. I'll be back tomorrow so I'd say I'll be over there for sure.0
