Insulating open trusses.
kcopp
Member Posts: 4,663
What doing a staple up radiant floor w/ plates and the floor has to be insulated.
How does one go about doing a good job when using batt type insulation when the trusses are open on the sides? What practices have you seen done that work?
What rvalue batts? What are truss centers? Double top cord plate?0
From the pix it looks like 24 oc. single top plates. open webs. prob do r-210
Well I can think of a couple ways good, better, and best.. easy, hard, and harder. Depends how much mechanical is up in that region.
Spray foam
1x8 nailed to side of truss to hold insulation batt, and isolate the bay. Cut as needed to length to miss mechanicals.
Run rolls of tie wire pulled tight perpendicular to trusses fastened at cord locations to desired height to hold batts in position. Probably 2’ oc. May be the easiest.
If it were 16” OC I would have said 24” batts cut around cords and stapled to cords.
Why batts?0
Better yet, bi-directional radiant heatingGordy said:Could just say I’m throwing ceiling radiant in for free
..........kidding.
ME
2
- 52 Job Opportunities
- 19 Recall Announcements
