what thermostatic mixing valve is this
Janneke
Member Posts: 1
in Gas Heating
Our thermostatic mixing valve is broken. The man that installed it in 2008 is retired. Does anyone have an idea in wich direction we have to search for a replacement?
We have consulted multiple repair technicians, but they don't know.
Try enware.com
Looks about right.0 -
looks close to a honeywell mixing valve, but check the dimensions for retrofit
"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0 -
The whole assembly looks Euro based. Clever wiring connection
Is it not mixing properly?
Sometimes they just need to be disassembled and cleaned. There is not much inside, a spool, o-rings and a copper thermal "pill"Bob "hot rod" Rohr
You can't find/ask the retired guy?
It does look all European. Roth manifold, Danfoss actuators, grundfos pump.
If I had to guess on the mixer, I would start looking to Roth for answers.0 -
What brand are the manifolds? They may be the supplier of the mix valve also or OEM it from another manufacturer.Bob "hot rod" Rohr
Where is this located?
Centigrade thermometer and different looking electrical outlet??0 -
It's an Roth manifold ,, Assume Euro with the 240V outlet ..
