Sediment Trap for concealed spaces
Hello, I have a question about installing sediment traps on CSST ran in a concealed space. In my situation the CSST was ran in a concealed floor then up the wall to a recessed gas shutoff valve, from there flexible hose was used to connect the shutoff to the dryer. Should a sediment trap be installed in this line somewhere? Would it get installed in the wall right before connecting to the shutoff valve?
The trap would want be accessible, usually just before the appliance"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
- 50 Industry Classes
