what thermostatic mixing valve is this
Janneke
Janneke Member Posts: 1
Our thermostatic mixing valve is broken. The man that installed it in 2008 is retired. Does anyone have an idea in wich direction we have to search for a replacement?
We have consulted multiple repair technicians, but they don't know.
    HVACNUT Member Posts: 7,315
    Try enware.com
    Looks about right.
  • newagedawn
    newagedawn Member Posts: 586
    looks close to a honeywell mixing valve, but check the dimensions for retrofit
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
    hot_rod Member Posts: 27,104
    The whole assembly looks Euro based. Clever wiring connection :)
    Is it not mixing properly?
    Sometimes they just need to be disassembled and cleaned. There is not much inside, a spool, o-rings and a copper thermal "pill"
  • STEVEusaPA
    You can't find/ask the retired guy?
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,281
    It does look all European. Roth manifold, Danfoss actuators, grundfos pump.
    If I had to guess on the mixer, I would start looking to Roth for answers.
    What brand are the manifolds? They may be the supplier of the mix valve also or OEM it from another manufacturer.
  • JUGHNE
    JUGHNE Member Posts: 11,527
    Where is this located?
    Centigrade thermometer and different looking electrical outlet??
  • Big Ed_4
    Big Ed_4 Member Posts: 3,417
    It's an Roth manifold ,, Assume Euro with the 240V outlet ..
