Replacing the Aquastat on a ss-30 HTP tank
mcassani
Member Posts: 7
I need to replace the aquastat on my water heater but the oil company says you cant and tried to sell me a new tank. It that true? Seems like an easy replacement if I can get the part.
How about a few pictures. You should be able to replace it.
What problem are you having with the water heater?0 -
here is the unit
Looks like a dry well. Why they ran hard pipe for 18 gauge wire I don't know local codes maybe. You should be able to get another L4080B1295 honeywell and off you go.0
I did find one but do I need to replace the pipe it slides into in the water heater?0
The conduit is from the original install. The unit is 19 years old.0
No that is a dry well. The new control normally comes with some goop that gets every where so use it sparingly.0
What issues are you having?
There should be a screw on the opposite side from the pic holding the aquastat to the well. Loosen the screw and pull the whole assembly out of the well.
Is the well stainless? It should be. Not brass.0 -
Do us a favor and ask the oil guys what’s the reason for needing a tank replacement....Are the oil guys a tech. company or just a delivery company....sounds fishy but one never knows, not being there on site....0
There from the service dept of the delivery company. The probe is brass but the housing tube (i think called the dry well) looks stainless.0
That's a brass fitting with a copper well tube. Unless it is leaking or the aquastat bulb is seized in side if it , there is no reason to replace the well. But as asked before is there a reason to replace the aquastat? They do fail but not that often. Is it not calling the boiler or pump?
The old aquastat comes right out so it's not seized. It's not regulating correctly. I turned it to max and the water gets warm just not hot. It's also 19 years old so had to go at some point I assume. The dry well is not leaking0
so you should be able to simply replace it. It's easy to do and they're not expensive.
I stand corrected. I thought I recall brass but it's been a number of years since I've installed one.HVACNUT said:> @Grallert said:
SS specs a stainless well.
Either way usually no need to replace the well.
O P, Wondering if the oil techs gave you an explanation as to why the wanted to change out the indirect...just curious0
When a tech doesn't know what to do, or what is wrong they say( "replace it, it's old").
Then you know it's time to replace the tech.
When someone want's to replace something really old for no reason they will say it's junk. I say if it's junk it wouldn't have lasted this long0 -
It could be that the stat is fine and the tank coil is plugged up.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
