2 zone heat system - Getting too much heat upstairs question
So, my guess is even though they shut the zone off downstairs it’s somehow bypassing and going upstairs and adding excess amounts of heat. I have figured out a temporary way to resolve this and it’s setting the basement thermostat to like 52 degrees so it wont trigger needing heat and in turn the upstairs seems to be where it should be and will only go off when it falls below 65. I don’t know if this is the right way to be doing it, but I don’t know what my options are until the new baseboard is put back in and the zone turned back on.
Any ideas?
Call the contractor that's working on your BBs, more than likely, he's done something to cause this.Bob Boan
Yeah, I figured that. I mean I can probably survive another few days if need be.0
Did he do any wiring at the boiler? Can you see the heat demand for the basement zone on WiFi?
If he did any wiring, it's possible he reversed the zones. Down thermostat controls up and up thermostat controls down.
Stand by the boiler and use WiFi to turn on the basement zone. If upstairs comes on instead, the contractor is from The Bizarro World.0 -
Nope he didn’t do any wiring at all. Just turned the valve off 2 of them for the basement zone. I can see the heat demand on wifi from the basement it shows a heat symbol, but of course because the heat isn’t on down there it seems to be going upstairs instead.HVACNUT said:Did he do any wiring at the boiler? Can you see the heat demand for the basement zone on WiFi?
So he closed the valve but didn't disconnect the thermostat?
I would start by shutting off that tstat0 -
Correct he probably had no clue how to control this ecobee. I have an option under my ecobee app to turn off the thermostat heat for just downstairs. Would that help?Leon82 said:So he closed the valve but didn't disconnect the thermostat?
Yes, the boiler is firing and the pump is trying to force the water. It may be going thru the flow check, which is normally not under as much pressure because there is flow thru the basement loop0 -
It won’t cause any issues by turning it off right? Just don’t want any pipes to freeze. I’m in Boston overnight lows this week are in the 20’s.Leon82 said:> @NickB2005 said:
Maybe a picture of where he closed the valve is in order. if it's near the boiler piping and you are still using the upstairs zone I don t see how it will freeze.0
I added a pic of one of the windows down there right now. It’s like wet but I’m not sure if it’s because they are plastering that room because the other room down there isn’t wet that hasn’t been plastered yet.Leon82 said:Maybe a picture of where he closed the valve is in order. if it's near the boiler piping and you are still using the upstairs zone I don t see how it will freeze.
That’s really helpful. Thank you. I have turned that thermostat off right now so it will no longer call for heat. They are installing new baseboards Tuesday or Wednesday this week as soon as plasterer is done. So, I should be ok? I assume the upstairs heat goes through the floor downstairs. I have the basement tarted off from upstairs so no debris comes upstairs and it’s pretty air tight. So there’s no other way I can think of that heat is getting down there.Leon82 said:You absolutely do not want that zone to call for heat. If they have already drained it the pump can be running dry.
Or you are getting gravity flow up to the top zone because the boiler is running because the basement wants heat and and the first zone is not pumping.
I still don't see how a zone that's completely isolated can force water through.... I get it now. Another pic or more info would've helped silly. You have P/S pumping? The primary pump is energized with a basement heat demand and forcing it upstairs.
Shut down the basement zone.
Looks like the basement is mostly below grade so there shouldn't be any issues with freezing.
Are you really having plaster work done? That's a lost art. Pretty cool.-1 -
Yeah, I shut down the heat on my ecobee for the basement it shows off now. Don’t know why I didn’t try this in the first place.HVACNUT said:I still don't see how a zone that's completely isolated can force water through.... I get it now. Another pic or more info would've helped silly. You have P/S pumping? The primary pump is energized with a basement heat demand and forcing it upstairs.
Yeah, it’s interesting I had all wood paneling down there so they gutted it all and insulated with some r15 since only r7 was there. They blueboarded it all the other day and started plastering Friday got 2 rooms done. They said they’d be done by Tuesday with all down there. It’s super messy, but really interesting watching them do it.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
