Radiator noise
mtlight
Member Posts: 28
I have 2 year old sunrad. It’s 22 sections and approx 50 inches. It recessed in my wall . In a call for steam and from a cold start this rad used to be quiet but now it has one loud ping as the steam moves from the first to the second section of the rad? It’s the only noise that it makes and does it every time the steam moves past that section. Could it be an expansion problem or maybe a pitch issue I’ll increase pitch and see
It’s quiet otherwise and a beast for heat. I’m not sure what’s causing this noise but would love it to stop. Thanks for any suggestions
You could try a piece of plastic milk jug under the legs to see if the helps. Put a level on it to make sure it has pitch and then a long straight edge to make sure it's not sagging in the middle.
3PSI gauge0 -
Ok. I’ll try that and get back. Hope no sag. Only 2 years old and problem right near the right leg by section two0
I raised the vent side maybe 1/8”. Middle not sagging and still when heat goes from 1st to 2nd section there’s one sharp ping!!! Every time. Annoying Could it be the tension rod in the rear? I guess live with it thru the winter. Maybe call the manufacturer and see wht they say. Just annoying. And advice is appreciated.
Thanks0 -
If there is a union on the point of connection between sections, loosen it a part turn, and retighten as it may be slightly out of line.—NBC0
I would back off the tensioning rod with the radiator cool then retighten to just short of snug. I know that's a vague description but try to get it just past finger tight... another pretty vague description, sorry
Try the piece of plastic under the feet. It sounds like expansion and probably hanging up on the floor making the slight movement difficult.0
It does sound like an expansion noise. I remember I had this issue where almost every single radiator in my house would bang when started to heat up or cool down. I put furniture coasters under the radiators' feet and everything became quiet.0
