Made a video about my hot water tank and mixing valve installation
cwilliams2000
cwilliams2000 Member Posts: 140
edited December 2017 in THE MAIN WALL
I am certainly no Spielberg but I did have some fun making these. If you have interest you can check it out below. If I have given any mis-information, etc. please feel free to comment. These are only to help provide some useful info.
Some of my other vids are more for fun and you might like also if you are into amphibious 6x6's, glass engines, etc.
Thank you
Hot Water Tank/Mixing Valve
https://youtu.be/Lq1iT1pqz_Q
    hot_rod Member Posts: 26,604
    Great! A clear, understandable explanation of DHW thermostatic mixing valves.
    One comment, when you install a T&P valve in a tee like that make sure the sensing rod extends into the tank. Most manufacturers offer extended sensor version like this 8" Watts brand 100XL8.
  • cwilliams2000
    Thanks Bob I really appreciate the feedback. I will also check the model tag on that T&P, hopefully its the right one oherwise I will switch it out too.
  • ChasMan
    ChasMan Member Posts: 474
    I much prefer setting the DHW temp on my De Deitrich Easymatic.. It has a Legionella timer on it, heats it up to 165 for an hour every week and then sets it back at night and advances during the day. How come TEKMAR doesn't do that? I only wish it had a contact for the recirc to clean out the pipes. What tempering valve do you have? My Honeywell is super inconsistent.
