Problem with Hydro Level VXT 110V
Hi Guys, having a problem (or I think I have a problem) with a Hydro Level VXT 110V. Boiler seems to be getting flooded over a 12-24 hour period. Please see attached picture. The meter continues to read 0. I have a union on the feed line to the boiler. When I break it there's no water coming through. Just wondering has anyone ever seen these units feed water periodically and not register on the meter? I've checked multiple apartments to see if I could find any other reason, but I cannot see where the boiler is getting the water from.
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,313
    If the boiler power shuts down momentarily, the feeder will feed momonetarily when it the controls power up again.
  • JUGHNE
    JUGHNE Member Posts: 11,513
    Could the control wiring be wrong so as to cycle the power to the feeder with the T-stat or pressure control. When it should, I assume, be powered continuously? Feeding as Whisperer suggested.
  • Fred
    Fred Member Posts: 8,542
    Is there a manual feed that bypasses the VXT? What kind of valve is on there? May be leaking past that valve.
  • New England SteamWorks
    New England SteamWorks Member Posts: 1,529
    edited November 2017
    We need a better picture(s) of how the VXT is piped. I only see one valve with the handle removed and wire tied.
    newenglandsteamworks.com
  • Steve_210
    Steve_210 Member Posts: 664
    It was a pinhole in one the hot water coil's,
    I just couldn't except that it could've gone within 12 months
    Stubbornness I know
  • I wouldn't have accepted it either...
