Steamer replacement Nutley NJ
Dave0176
Member Posts: 1,178
Home is vacant, foreclosure, under renovation, old Utica leaking installed in 1976, so 41 years not too bad. Removed a bulkhead tee and piped both risers to the header, and installed a little EG-30. Not finished still have to run electric, old boiler was power pile, main vents are just placed so I could run it and skim it. Rads need new vents and balancing, they are all Sunrads. Header is overkill but that’s the way I do things.
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
2
Beautiful installation as always Dave1
New England SteamWorks
newenglandsteamworks.com1 -
Finished, had to wait till the work was done on the basement floor.
I cannot force people to spend money, I can only suggest how to spend it wisely.......1
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
