Auto water feeder bypass
Trav
Member Posts: 8
My home steam system boiler has a Hydrolevel VXT-24 automatic water feeder installed. The water feeder's bypass button is electric, so if the circuit breaker is off or if the house temporarily loses electricity, the bypass won't feed water into the boiler if I press the unit's bypass button. Should I be reasonably concerned about this?
I ask because I'm in the process of selling my house, and at the prospective buyer's inspector's suggestion, the buyer is claiming that this is a safety hazard and needs to be remedied by me, the seller. I'm guessing they want a non-electric bypass to bypass the auto-feeder's bypass (if that makes sense).
Does anyone know New Jersey's state code on this? The auto feeder was installed by Joe Starosielec and his crew back when he was with Metuchen, NJ's Thatcher/ecuacool. It's my understanding that he has a stellar reputation here on the forum for diagnosing and treating steam heat systems. Since he went above and beyond in replacing my near-boiler copper piping with steel, and upgrading my whole system, I assume he'd be by-the-book as far as what's proper or legal for the auto water feeder.
Any info would be greatly appreciated!
-Travis
-Travis
I'd say it isn't a problem -- I might point out that if the power is off, the boiler isn't going to fire anyway.
However.
I'm not your local code enforcement officer, and she or he is the one to call the shots on this one. What they say is it!
I might also add, though, that installing a manual bypass shouldn't be a big deal -- and if that's what the buyer is concerned about and you want the sale, maybe just do it...Br. Jamie, osb
What @Jamie Hall said is correct. No power...no water feed. no power....boiler doesn't run anyhow.
I would tell the inspector (who always want everything) to pound sand.0 -
Thanks for the input, @Jamie Hall and @EBEBRATT-Ed. This is kind of what I thought.
This is the same inspector who said, "I'm not going to test the sprinkler valve since it's winter, but it looks rusty, so it needs to be replaced." I'm already making a large concession on the chimney, so I'm loathe to do any more for a seller whose low-ball house price I already accepted. Sheesh!
I guess it would behoove me to look into the local code here, but I'm assuming I'm on safe ground.0 -
An auto feed is a convenience item not a safety device. If the inspector doesn't understand this I would question his boiler knowledge.
If it's a real problem, offer to completely remove the auto feed and just have a manual valve. As far as I know auto feeds aren't code at all, just the LWCO.0 -
Does your installation look like this? If so, that center valve is the manual bypass.
I like this idea
Then tell them be careful what you wish for0 -
Here's another thought. Since the concern is the power going out, ask the inspector how the boiler fired while the power is out?!
The inspector is honestly making crap up or is completely clueless.0 -
I'm actually surprised he plumbed it without the manual bypass. @KC_Jones The Hydrolevel VXT-24 I&O manual does say the "Manual Bypass MUST be installed". I think the issue goes well beyond a power failure, like maybe the auto valve sticks closed and the LWCO has failed or whatever.0
He's right for the wrong reasons. You should have a manual way to add water to the boiler. What if the feeder crapped out? The original guy who installed it screwed up. It should be fixed.New England SteamWorks
newenglandsteamworks.com0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
