oil tank vent whisle
dreads
Member Posts: 17
in Oil Heating
My oil tank whistle is clogged. I want to take it out and clean it or replace it. In the vent pipe is a union? (see pics) looking at the union the left side seems to be where it should come apart. When I put the pipe wrench on the middle part and pull down the middle moves but so does the right side at the pipe it is attached to and not the union. I am "assuming" the right side piece of the union is frozen to the middle. Am I correct and any suggestions on how to free it. I have been putting penetrating oil on it . Thanks
You have to use two wrenches one to loosen the union nut and one to hold the other side.
First, get two hammers, put one behind the union nut and hold it tightly to the nut and hit the nut from the opposite side with the other hammer a few
times. A big hammer on the back and a smaller hammer to hit with
Works every time0 -
I'll add 2 bigger wrenches and/or 2 cheater bars.
When you say 'clogged' do you mean not whistling? Looks like
1 1/4" pipe so it may be the driver is fueling at high speed. Either way you may need a new whistle all together, and it may not line up when you re-install it.
ONE VERY IMPORTANT NOTE, because you are doing this yourself. Put a baggy over the fill pipe with a note in it "Do Not Fill, Tank Disconnected". Just in case you have to run out and get something, or stop to answer the phone, and either your regularly scheduled delivery or someone delivering to the wrong house starts filling up your tank.
Also, no teflon tape, just pipe dope when you re-install the whistle.
I'd also recommend having someone watch the next fill up, just to make sure everything is correct-whistling and no leaks.There was an error rendering this rich post.
Thank you both I will let the penetrating oil soak a little and then try. STEVEusaPA Can filling too fast cause the whistle not to work? Because it seems as if the whistle was working sometimes? I thought maybe I could heat the union with the torch! Only kidding. "Any one have a match I think I'm out of gas"0
Older whistles and smaller pipes vs. newer trucks with higher pump pressures.
Easiest way to tell is have the driver hook up, low speed, start pumping slow, gradually increasing to fully open. You should hear the whistle the whole time. If you hear it then it drops off, then it's the higher pressure fill.
Keep in mind by code your vent should be equal or larger than your supply piping so the vent can properly relieve the pressure of filling.
From the looks of your pictures, I would recommend you replace the whistle and piping and bring it up to code.There was an error rendering this rich post.
Yeah...I wouldn't do that. Next fill it blows that out the vent and gets on...who knows what.newagedawn said:i pour sludge clean down the vent pipe, if your lucky it will loosen up the crud in the whistle, its a fifty fifty shot and the sludge clean wont hurt your tank either
1
