insulate boiler room walls?
dvi2020
Member Posts: 34
in Gas Heating
I'm having a new direct-vent wall-hung high efficiency gas boiler installed with an indirect hot water tank. The boiler room is in the basement 13' x 4' with 6' ceiling. Concrete walls and floor, partially below grade with one window. Should I insulate the room before intallation? Will it make a significant difference in cost savings or heat loss from the boiler and tank to the cool/cold room? The pipes will be insulated.
If so, how should I do it. One option is to actually frame out walls with 2x4's, add pink insulation and cover with fire rated sheetrock on which to hang the boiler. However this is a lot of work and I'm wondering if it's worth it and whether there is any other method. I understand that exposed foam on the walls is a fire hazard and would fail inspection.
Thanks for any insight.
David
David
Passaic county in northern NJ0
The rest basement will eventually be finished and heated but not for another three years. The boiler room will have a normal door separating it from the rest of the basement, not a louvered door.0
Use XPS foamboard against the concrete foundation for insulation, it has better moisture repelling and drying properties than fiberglass. Still need framing to hold the sheetrock firebarrier up.
The insulation probably won't save much energy, but it will increase comfort, and that's important too. There is a warm spot in my kitchen floor above the boiler which is nice in bare feet.Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg1 -
thanks. it sounds like the consensus is that it's not worth it which contradicts what I've read. Is that because it's a high efficiency boiler and not a cast iron?
if i use XPS it looks like it's only 2" thick so I could frame with smaller 2x3's instead of 2x4's..if you think that's permissable...0 -
you do not want to use fiberglass. The strategies for insulating basements are changing rapidly due to discoveries that vapor barriers hurt more than help. You either let the vapors flow into the living space, or you completely block them with XPS and tape/expansion foam the seams. you will capture moisture in the wall using fiberglass. Don't do it up against the concrete/cmu's1
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
