Crack in furnace ?
sldamiano
Member Posts: 41
I was replacing my thermocouple and noticed a bit of a water drip. Stuck my phone in there a took a pic. How bad is the damage ?
It won't buff out, you may want to start budgeting for a new one.
How old is it?0 -
What does buff out mean exactly?0
It's not an easy fix, of it can be pulled apart the gaskets can be changed but if it goes south you will need a new one anyway0 -
In auto body work, a small imperfection in the paint can be taken care of with a buffing tool. This means it's not a major project. The expression has come to mean something that can be easily fixed.sldamiano said:What does buff out mean exactly?
But that's not the case here. Where are you located? We might know someone who can help you.
Consulting0 -
Understood. I’m located in Johnston Rhode Island and from what I understand it’s about time for a new one0 -
Not sure if @Charlie from wmass will come that far- if so, he's an excellent choice. Otherwise, try the Find a Contractor page of this site, here:
https://heatinghelp.com/find-a-contractor/All Steamed Up, Inc.
Consulting0 -
Thank you. I mean I know you can’t really tell but should I be calling someone to look at that ASAP?0 -
Call him and see.All Steamed Up, Inc.
Consulting-1 -
Also @New England SteamWorks is out of Rhode Island. You can find his information on other posts I am sure they can do a hot water job. Pictures of their work are excellent.-1
That would be another fine choice.All Steamed Up, Inc.
Consulting0
