Pipe insulation asbestos
daveamir
Member Posts: 69
Hi guys wondering if anyone would be able to tell me if my pipe insulation is asbestos thank you
Oh no that's not good0
Any suggestions what I should do0
New England SteamWorks
newenglandsteamworks.com-1 -
You can leave it alone and never touch it. You can have it encapsulated by a certified company or you can have it abated by a certified abatement company. If you go that route you want to have those pipes reinsulated. New England SteamWorks Is right, don't panic
-1 -
Ok I just have little kids so I got a little worried I guess I will find someone reputable to take care of this thank you0
You can leave it alone and never touch it. You can have it encapsulated by a certified company or you can have it abated by a certified abatement company. If you go that route you want to have those pipes r3 insulated.
-1 -
Thanks for the help guys0
The only way to know for sure whether it is asbestos is to have a sample tested by a certified lab. So before you spend any serious money, make sure you do that first. Judging by the picture, it most likely is an asbestos containing material.
Asbestos is safe if left undisturbed. So the safest thing might just be to leave it alone. If its presence worries you, then have it professionally encapsulated or removed by a state licensed contractor. Paying a non-licensed contractor to do the removal can get you (and them) into some very hot water.
You can also do the removal yourself as the homeowner, and you should follow procedures for minimizing contamination. And you must still follow state and federal regulations for the proper disposal of the asbestos. You can pay a licensed company to take the asbestos materials away after you do the removal.-1 -
Don't remove it. Just have someone seal off those exposed ends. If it doesn't get into the air, and is left alone, it is safe.
Make sure your kids know not to mess with it...just as anyone should tell them not to eat paint chips in an old house.0 -
I think if your system is working properly and you're satisfied with its operation, how it's piped, etc. then by all means, having someone come in and seal it all up is a worthwhile option.
However if there are currently issues, or if you think there is additional work or changes that need to be done on the system, having it sealed up will obviously hinder this.
I faced a similar situation last year when I bought my house, it had a mixture of old asbestos and some fiberglass - I chose to have it removed and abated. It was the more expensive option but now I don't have to worry about it.0
- 116 Geothermal
