EXpansion tanks
Charles99669
Member Posts: 4
can anyone tell me the difference between a boiler tank and a radiant tank- as far as I can see there is no difference ?
The terms you're using aren't industry terms. Need more information or pictures of what your looking at/talking about.
ME
mark iam trying to find out what the difference between a amtrol 15 and what the reps call a radiant expansion tank0
Here is the tankBob "hot rod" Rohr
tanks hot rod !!!0
The only difference between the two is that one of them can be used with non oxygen barrier tubing, and the other can't. Their potable water expansion tank is the same as the radiant exp. tank, but will need the diaphragm pressure lowered to the same operating pressure as the appliance it is serving. I believe it comes precharged at 40 PSI, versus a heating tank precharged at around 12 PSI.
ME0 -
And the connection size on DHW tanks is 3/4
MEBob "hot rod" Rohr
Living the hydronic dream1
- 52 Job Opportunities
