Low Loss Headers
Jim Kelleher_7
Member Posts: 10
What is the deal with low loss headers and the pricing ? I like one low loss Seperator 1" pipe size ran me over $350.00 ? I can buy a 50 gallon electric water heater for less money.
function -wise, properly piped either can be an effective separator.
With a top quality separator you get excellent micro bubble air removal, a 5 micron dirt separator at the bottom, and a magnetic function if you desire, and of course hydraulic sep. So 4 functions in one product. Magnetic function is a good idea if you chose ECM circulators.
The tank can add some buffer capacity and that may be a determining feature. I'd at least add a good air sep with a buffer tank. The tank alone with a float vent on top is not adequate for micro bubble removal, from my experience.
Living the hydronic dream1 -
Just a comparison I reckon, an electric water heater would seem to requires alot more effort to build, than a low loss header. I wasn't going to use a 50 gallon water heater as a buffer tank.0
With a bit of fitting trickery, it is possible. Most tanks only have 3/4 taps, but you can combine them or increase right away with a bell. depends on how many gpm you want to flow.
Here is my system with a Lochinvar Nobel and a small electric tank buffer. A two pipe buffer. I added a 4.5KW element for the times I run out of LP
With the larger electric tanks that have two elements, remove the elements and use the 1" element ports as your in and out. Air vent on top, bottom of the tank becomes the dirt separator function.
Here is a job I did probably 12 years ago to add so buffer to this cast boiler. These pics are still on a floppy from my Sony Mavica!
Or add one more step and put a magnet in a well at the bottom to collect magnetite.Bob "hot rod" Rohr
That pretty cool !0
@hot rod said: "These pics are still on a floppy from my Sony Mavica!"
Those were great cameras. Makes me wonder if I still have mine?? Haven't seen it in a while. Gotta go look0
- 116 Geothermal
- 169 Indoor-Air Quality
