Lower temperature
JoeFabian
Member Posts: 3
Have a customer with 3'' hot water heat mains running through basement apartment that are painted. It gets very hot in unit and heat can not be lowered due to building, many units, one boiler,etc. No radiators in unit just the overhead heat mains. Any suggestions on how to lower temp. Thanks Joe
Insulate the mains.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes3 -
Solved0
Insulation is ok when its too hot but if the temperature dips down to 15-20 degrees and you want the heat back you can't keep removing and reinstalling the insulation to regulate the temperature in the apartment. Insulation was the first thought, boxing in the heat mains in with adjustable grates. This is time consuming and pricey and who knows if it will work.0
So insulate a few feet of it and test it out and if it's still too hot had a few more feet of insulation staggered in like 5 foot length or something0
Sounds like a real good idea. I am going to talk to my customer about your suggestion on staggering the insulation sections. Thanks0
Put an outdoor reset control on the boiler and control the pipes output...
ME0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
