looking for screw in insertion electric element for old water tank/range boiler
vibert_c
Member Posts: 69
I have run out of replacement elements for my 1929 copper #30 hot water tank.
Are they available in the U.S.A.?
220 volts, 1" NPT screw in mounting, any wattage up to 3kW
I have never seen 1" screw in elements. Seems like this thing needs replacement ..... almost 90 years old0
1" threaded elements are the most commonly used types in the electric DHW market. You can find them most everywhere, plumbing suppliers, hardware stores, box stores, online. They are available in all sorts of lengths and wattages, and long life ones like the Sandhog.
Most use a small ring gasket also to seal.
Make sure you have a good working temperature and pressure relief valve if it is a pressurized vessel.Bob "hot rod" Rohr
The common electric element is 240 VAC 4500watts.
IIRC there are some 240 vac 3000 KW, might have to order.
Is there a nameplate with the max KW? I know 1929..0 -
@EBEBRATT-Ed They made quality products back then. Why can't a hot water tank last 90 years! It has blown out three elements in that time. Nothing else can survive my well water where I reside. A modern tank is lucky to last 15 months.
@hot rod these units seal on the pipe thread not on a gasket.
I have tried your recommended flavor with the gasket, but can't make it seal as the collar is not flush where it screws in.
@JUGHNE no name plate, just a stencil on the tank, CRANE 1929.
Thanks for the support guys.
Any way to take an angle grinder or file and make a flat surface for the gasket?
I'll bet you could clean the threads real well and get some blue, or green Loctite and basically glue the threads. That is how most brass ball valves and straight threads are assembled.
We assemble all our brass manifolds with Loctite 272 or 575 and within a few minutes air test at 90 psi, it " goes off" quickly in the absence of air. Loctite is basically a super glue formulated for hydronic and pneumatic fitting assemblies.Bob "hot rod" Rohr
@hot rod That is a great suggestion. I was hoping to find an original element. I am not stuck right now as this unit is also plumbed with a functional side arm heater {low, med, high]
I have run a 1" tap through the threads so they are clean. I do have a modern gasketed element to try with the locktite.
Thanks0 -
Here are the two #s we use. I like the 272 series for loose threads, it is a thicker consistency, 545 seems to be more permanent.
For a time we sent these small on fitting tubes out with manifolds to make field adjustments, I may have some around if you can't find small tubes locally or online.
WATTCO has or will make whatever you want0
Is this water heater in the US or the UK?0
- 116 Geothermal
- 169 Indoor-Air Quality
