Lennox Pulse
Justasking
Member Posts: 1
in Gas Heating
I have a Lennox Pulse which has worked well for 20 years. Now it doesn't respond to the thermostat's call for heat. I can switch the power off and on and then it will work okay for maybe a month. Is this a furnace issue or a thermostat issue?
Check the wiring, make sure it isnt loose or corroded. When it doesnt work try shorting together the red and white wires at thermostat see if it works. If it does, potential bad thermostat. Check batteries in thermostat, if any. Make sure exhausts/intakes are free of restrictions. Make sure gas pressure and electric power are ok. Any error lights/indicators on the unit that may be telling you something?0
When was the last time you had it serviced??
Although gas appliances are usually trouble free they should still be checked and serviced especially @20 years old furnace0 -
The furnace is obsolete and Lennox is not offering parts anymore. They want the heat exchanger pressure tested since most all of them have failed. That costs a lot more than that old furnace is worth.
If it's not something minor, you need to look at replacing it.
Check the condensate drain lines and make sure ALL (inside and out) of them are clear.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
20 years; it's lived a good life. Time for a new one.1
That and the "Complet Heat" were two Lennox disasters. Time to change for a HTP or Lochinvar!0
If your condensate drain isn't clogged I'd bet money you need a new board. Those just don't last. The Pulse is tough to service and not a popular furnace amongst the pros... me included!0
It is a very good furnace. Just that many of them were not installed properly. I have two in service 26 years. You are supposed to replace the check valves every five years I believe.0
They lasted less than 10 years here with multiple issues!0
- 87.7K THE MAIN WALL
- 128 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
