Cast Iron hot water valve adjustment
Jerryrw
Member Posts: 4
The old cast iron radiators in the house I'm working on are hot water and bottom piped on both sides. Instead of just an elbow on the return side, there is a valve with a lock nut and screw adjustment. Feed side has traditional knob adjustment. Cant find any info on this double valved arrangement specifically how to adjust heat on individual radiators. Thanks
Post some pics, please.Bob Boan
Ok I will post some pics. The prob is this radiator overheats the room. Thermostat is in another room and wanted to adjust it (radiator) for less heat. Not sure which valve to use, since I've never worked with these before. Thanks0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
