testing a mains air vent
bcoyle
Member Posts: 29
Is there a way to safety test if a vent is working? Specifically I can't tell if the Gorton no. 2's on the basement mains are working. Do you put something up to the vent to see if air is escaping. I can't tell if it's just too slow/gentle to notice or it's plugged. I also think of the two mains in the basement, we might need a big mouth or two. Which would be exciting. Need these mains to heat up faster.
A strip of tissue will flutter if the vent is venting air.
3PSI gauge0 -
Just tell the wifey that those damn vents died, AGAIN and order a couple Big Mouths. They cost the same as the Gorton #2" with twice the venting capacity.
Need some more info. Are the mains insulated? How long are the mains? How long does it take to get steam from the header to the main vent?0
@Mark N Mains are mostly insulated, at least on one of the two main pipe runs. I'm going to measure the mains tomorrow. Any suggestions for testing the speed at which the mains heat up? I can mostly just run around the basement trying to feel the piping. Hopefully by tomorrow I'll have a 3d diagram to help visualize the piping.0
The goal is to get the mains to vent as fast as if they were venting to an open pipe. What size is the nipple the vent is mounted to? With a cool main,take the vent off of the nipple and fire the boiler up. Once the header gets hot, go to that open vent pipe and time how long it takes to get steam to that end of the main. Turn the power off to the boiler immediately. That time is the best you are going to get, with a vent opening the size it currently is. . Add vents to the main until you achieve about the same time to get steam to that end of the main.1
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
