What schedule pipe for an equalizer
Schvenzlerman
Member Posts: 41
I have a Weil McLain LGB-6 steam boiler. A section of pipe and a fitting on the equalizer are rusting on the outside to the effect of a leak. What schedule pipe should be used? The boiler was installed around 1997. I run it at 4 oz. cut-in and 10 oz cut-out with a Vaporstat, but I assume that's not relevant to this pipe issue.
Thanks appreciate the advice.0
Agreed. Schedule 40.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
