Weil McLain Gas Boiler water vent valve
Bubbyt4u2
Member Posts: 1
Hello to all. I have a 25 year old Weil McLain gas boiler water vent valve #78 leaking. Can these valves by rebuilt? (if so, where to get a kit) or is something more modern used in place of this #78 unit? Not only is this valve hard to find in my area..but terribly expensive. Thanks.
Is this a pressure relief valve, or a device for relieving trapped air in the system?--NBC0
Is that the Hoffman? That's for a high pressure system I believe..0
It is for a high pressure system. Available at Supply House:lchmb said:Is that the Hoffman? That's for a high pressure system I believe..
http://www.supplyhouse.com/Hoffman-401485-78-3-4-Straight-Water-Main-Air-Valve-3830000-p0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
