Loving Taco Pumps
Harvey Ramer
Harvey Ramer Member Posts: 2,281
Pumping 7,000 sf of radiant with 100 watts.
Rich_49
  • cwilliams2000
    cwilliams2000 Member Posts: 140
    Very cool and nice looking install. Would love to see more pictures of the equipment in that space.
    Harvey Ramer
  • STEVEusaPA
    You maniac! Love it. Very nice Harvey....and yes, more pics please
    Harvey Ramer
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    edited November 2017
    Is that an old Onyx system?
    More pics!
    Harvey Ramer
    hot_rod Member Posts: 26,594
    nice piping work. What brand air sep? Does it have a flow direction, seems close to turbulence. It looks like the casting has more distance on one end compared to the other? Or just the pic angle.
    Harvey Ramer
  • Harvey Ramer
    More pics will come. I need better lighting to get a good picture. Currently waiting on the construction company to finish the walls and ceilings.
    That air separator is made by Watts. The flange that connects to the pump is a swivel flange and also has a short piece of straight pipe casting. There is turbulence in the air Sep. I can tell by the fluttering gauge directly below. But to be fair, I am pushing the max gpm that it is rated for. I chose it for the space savings. If not for that, I would have had to do some creative piping.
    The air Sep doesn't perform on the same level as a Sep piped in straight and level piping. But than again, neither does a vertical Sep. It will work great in this application, as it is all low temp radiant. After a good purge, there is not much air to be released from the water at such a low temp.
  • archibald tuttle
    archibald tuttle Member Posts: 1,162
    but think of all the electricity that LED display is eating up . . . gotta love information though, what i want is a really reliable display of flow and temperature . . . can you get those as an output from that pump . . . sometimes in low temp, low delta situations it is hard to just use the hand test for if the pipe is hot to 'measure' flow.
  • Harvey Ramer
    The Pump displays Watts, Ft of Head, GPM, and RPM. According to the flowmeters on the manifolds, the GPM readout is fairly accurate.
  • Harvey Ramer
    More pics!
    No, most of it is Mr Pex. The black tube you see are 2 small loops of viega pex for 2 bathrooms.
  • archibald tuttle
    does it take sensors so it can display feed and return either from a primary loop or possible from several loops. that would allow it to integrate the GPM to give a BTU reading as well..
