Running boiler with only 1st floor hooked up (Steam heat)
detroitjim
Member Posts: 3
Is it ok to run boiler with only 1st floor radiators hooked up? Radiators for rest of house haven't arrived yet. Want to take chill out of house. Rest of systems has valves that are shut off
One pipe steam?0
yes
If you have old valves on the second floor you may find out which ones do not shut off 100%.
The boiler will probably short cycle on the pressure control, a lot if you do not have enough main steam line venting.
But you should get some heat to get you thru.0 -
Great! Thanks so much. Just didn't want to jeopardize anything0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
