CI Baseboard assmby
kcopp
Member Posts: 4,630
When installing CIBB is it required to have the assembly tool? I was under the impression that the newer versions you just needed to snug up the bolts.
Yes still need that tool0
I installed some GOV-Board (same as Burnham BaseRay) over the summer... you do need the assembly tool.0
Thanks... took a bit but I found one.
