CI Baseboard assmby
kcopp
kcopp Posts: 4,739
When installing CIBB is it required to have the assembly tool? I was under the impression that the newer versions you just needed to snug up the bolts.
  • Sam81
    Sam81 Posts: 37
    Yes still need that tool
  • NY_Rob
    NY_Rob Posts: 1,370
    I installed some GOV-Board (same as Burnham BaseRay) over the summer... you do need the assembly tool.
  • kcopp
    kcopp Posts: 4,739
    Thanks... took a bit but I found one.
