Bleeder valve stuck crushed-what should I do
I changed a couple others no sweat, they were old. This one was newer and it looks like it is fully cranked down. It seems to still be holding pressure, when I turn the screw I hear the hiss and I can then close it.
Couple things:
- The system is empty- the hiss is from water falling out.
- I was working on a bigger project on another thread-this was the last step-was helped by this board-hoping for a little more.
- This is a hot water circulation system (no steam)
- just crushing the thing and trying harder to turn it out
- Maybe a blow torch?
- Maybe drill out the middle and use needle nose to pull out the reaming metal-trying to preserve the threads?
- Just leave it-this irks me to do this
- What else???
I would take a dental angle pick and cut away the paint to expose some threads. Then spray with Kroil or PB blaster and let soak a couple times.
If it does twist off then you have to drill out the remaining parts.
They are usually 1/8" pipe thread. Then a good easy out might remove the guts. Retap with the correct 1/8" pipe thread tap.
If you drill into the rad threads then get the right drill size, drill and tap for 1/4" pipe thread. Install new vent with 1/4" X 1/8" brass bushing.0 -
Amazing! thank you. you are correct about the current thread size-see the part that I am replacing with.JUGHNE said:I would take a dental angle pick and cut away the paint to expose some threads. Then spray with Kroil or PB blaster and let soak a couple times.
Question. If I drill carefully why would I need to retap with 1/8" thread? I get if I fowl the thread I should go to 1/4. Just trying to understand and avoid do more thing because I don't want to fowl the radiator.
Thank you!
It's going to be hard to drill it straight. Make the hole undersize and use the easy out like suggested.
The retap will ensure a good seal.0 -
Got it. whoever put this one in tightened it so much it is practically flush with the radiator.Leon82 said:It's going to be hard to drill it straight. Make the hole undersize and use the easy out like suggested.
If I have to go to 1/4 it the metal hard to drill or is it soft-ish.0 -
It looks like iron so it will drill fine. Just go slow. I would still set a stop if you have one so you don't over drill if it grabs on you.
Try to get a "feel" for the easy out. It is hardened and you don't want it to break.
Don't send the tap all the way in either. It is tapered and once the fitting starts inside I would go in half turn increments untill it feels like a good depth. Guage it with an existing fitting0 -
I GOT IT WITH PB PLASTER! knowing how to fix it gave me the confidence to bite into it more with the wrench and it released with the pipe wrench. Am I good to just put the new one in or are you still thinking I should tap. threads look good!Leon82 said:It looks like iron so it will drill fine. Just go slow. I would still set a stop if you have one so you don't over drill if it grabs on you.
Don't send the tap all the way in either. It is tapered and once the fitting starts inside I would go in half turn increments until it feels like a good depth. Guage it with an existing fitting
Thank you1 -
If you test fit the new valve and it feels good you should be all set. Use some teflon tape on the new valve when you really install it.
3PSI gauge0 -
I did. 4 wraps with teflon take and pipe dope too. Its on and I am about to fill the system and test for leaks.BobC said:If you test fit the new valve and it feels good you should be all set. Use some teflon tape on the new valve when you really install it.
Bob
Fingers crosssed and thanks!!0 -
Thank you! knowing what to do if it went bad helped me get it. knowing that I could expand to 1/4. huge help!!Leon82 said:Nice. 1/8 doesn't need much force to seal, the previous guy did not know finesse
Water on and all valves are solid and air tight.0 -
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
